disable ntp authentication
Description
Disables NTP authentication globally on the switch.
Syntax Description
N/A.
Default
NTP authentication is disabled by default.
Usage Guidelines
If authentication is disabled, NTP will not use any authentication mechanism to a server or from clients. To use authentication for a specific server, enable NTP authentication globally, and then configure an RSA Data Security, Inc. MD5 Message-Digest Algorithm or SHA256 key index for the specific server.
The following command disables NTP authentication globally on the switch:
# disable ntp authentication
This command was first available in ExtremeXOS 12.7.
Platform Availability
